Home pos lost if job is stopped
Hello all!
I am facing a little problem. If i stop a cut (for example because i mistyped the laser power to 8 instead of 80) it loses the home position, forcing me to home again the laser. This also messes up the focus and i have to refocus my laser risking to shift the workpeace.
can this be avoided? or is it possible to home the laser without homing the Z axis but also without disabeling it in the software?
Thank you!
PS: I have a ATEZR L2 24W laser.
If the firmware supports it, you can try to home via the $HXY command in the console window. This should home only x and y. If that works, you can create a macro button there to access it even faster.
unfortunately that does not seem to be working… :frowning:
