Hello,
After update to 1.1h (original .hex from vendor) my homing is broken.
First docking to wrong dirrection so i change $2 mask to correct dirrection homing move.
But home possition is -890 of origin and laser go to 0 when i set laser posion to left corner in ligtburn.
concole
<Idle|MPos:-899.000,-899.000,-1.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:-899.000,-899.000,-1.000|FS:0,0|Ov:100,100,100>
ok
Some additional things to the ones Mike already mentioned:
Usually, you never change $2 to change the motor direction, always change $3. Make sure that the arrow buttons work correctly. If not, change $3 until those work correctly.
If homing is not working correctly then, change $23 until that works as well.
Thanks guys for yours quick response.
Problem was in .hex from chines vendor. If i compile own firmware with HOMING_FORCE_SET_ORIGIN enabled, its worked good.
Its solved and working good now.
