My machine is is set up at 18" in the y, 32" in the x. I would expect it to home at X0Y18, however it is now homing at 0, 6.692. No matter what I do I can’t change the y value. With the 6.692 set, and my machine max y travel at 18", the y direction travel only is about 11.3" at current before it stops so I can’t travel in the complete Y available space. Where it stops, the position is indicating 0,0 but is well short of the actual machine origin true 0,0. I have a Neje Master 2S Max. This issue just popped up as I used to have full range.
I pulled the power on the unit today and ever so slowly manually moved the unit to the machine origin. When I finally got it there, plugged in the machine and connected it to LB it was indicating a position of 0,0. I hit ‘Home’ and it stopped at the same spot it was stopping previously heading the opposite direction and gave me an 'ALARM:9 Homing fail" error. After this it again called this point, in the middle of my y axis 0,0. Any thoughts on what I can do?
If not and this was recently done then this sounds like it could be a work offset issue. Can you run these commands in Console after a homing operation?
Not to my knowledge, but I’ve been checking a lot of functions this week trying to figure out this issue. When I look at how the laser is setup in LB, it is at the 32x18. Is there a way to change those settings in LB now, or should I look for an update from Neje?
Run the two commands I list. I suggest also specifying your work area in mm rather than inches as that’s how it’s designed. You can work in inches no problem.
push the units button on the numeric edits toolbar
go to Edit->Device Settings
set work area to 810x460, then OK
you can change the units back to inches if you like in numeric edits toolbar
That worked! Get rid of one problem now trying to fix the next. Now, the laser keeps pausing. Tried 3 different runs. First time it went to .5%, next 2 %, this time 4%. Stays ‘Busy’ like it is still doing something but program and laser not moving. Any idea?
Thanks for your help. Still working on the stopping issue. Checked all the components and drivers out and they seem ok. Going to work on some static control this weekend.
