Homing cycle is not enabled in your Grbl settings. error:5
Hello,
I have a Yora laser and am getting the below message.Homing cycle is not enabled in your Grbl settings.
error:5
My laser is moving towards the home position, however it goes past it and starts hitting the bottom left hand corner of my machine, How can I reset my home position ?
I have a Yora Laser.
Many thanks,
Assuming it’s that machine, does it have home switches?
The picture of the controller suggests it does not, in which case you must always put the laser head in the home position before turning the power on:
Then you must never click LightBurn’s Home button, because that requires homing to be enabled.
That’s what happens when LightBurn sends a Home command to a controller without homing enabled.
