I have been using NEJE Max 4 for almost the last few months and have been working very fine till now, I did a few of the updates of the Lightburn software, and since then I have been having issues of the “Homing” but somehow it was not giving any trouble in working but today I found that it has started giving me error in my Job as well, I mean laser was not moving as per the giving job command, if I start the job of Square cutting then it will do weird shape and even Z move was also getting wrong.
Below are the settings I got from the machine
$0=10
$1=255
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=1
$24=250.000
$25=2500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$40=0.200
$41=10
$42=10
$43=0
$100=80.000
$101=80.000
$102=800.000
$103=8.889
$110=24000.000
$111=15000.000
$112=1200.000
$113=21600.000
$120=400.000
$121=250.000
$122=20.000
$123=250.000
$130=750.000
$131=460.000
$132=45.000
$133=360.000
I have plugged out power and connection cable and replugged it and it has solve the issue for a short time but when i did a small job in the middle of the laser bed and given command to go home back, it has again given me the same trouble. Few more setting what I have copied from the machine are below
"[VER:1.1f.NEJE build version:v2.1.1:]
[OPT:VMZHL,199,1000]
Target buffer size found
ok
Homing
ok
ok
<Idle|MPos:0.000,460.000,0.000,0.000|Bf:199,1500|FS:0,0|Pn:P|WCO:0.000,0.000,0.000,0.000>
ok
Starting stream
Job halted
Stream completed in 0:00
Grbl 1.1f [‘$’ for help]
[MSG: GRBL offline working see: GRBL Offline Work | NEJE Wiki ]
ok
<Idle|MPos:0.000,460.000,0.000,0.000|Bf:199,1499|FS:0,0|Pn:P|WCO:0.000,0.000,0.000,0.000>
ok
Starting stream
[MSG: Laser temperature:25.2C]
[MSG:Pgm End]
<Idle|MPos:25.000,460.000,0.000,0.000|Bf:199,1500|FS:0,0|Pn:P|WCO:0.000,0.000,0.000,0.000>
ok
Starting stream
[MSG:Pgm End]
ok"
[OPT: VMZHL,199,1000]
ok
Homing
ok"
Can you please help me to solve this issue in permanent basis.
