I have a Universal Engraver. I’m running the trial version of Lightburn. When I try to run the laser I get a laser out of bounds error. How do I set my left, right, upper, and lower bounds?
It’s nice to have a link or something so we can tell what machine you have.
- Does it home?
- If so, which corner is home?
- Read the Lightburn Documentation on grbl setup
- Lightburn Documentation on the job origin and coordinate system.
That should get you going…
Thank you. I got it home, but I have to return it to home before I turn it off; otherwise it will not reset properly. I can’t got it to home on startup.
This doesn’t make sense…
It should home on a power up, reset or via a home command from Lightburn…
Please elaborate, exactly the steps and where it fails…
