Homing Issue Sculpfun S30
Home is not going to where home should be. I set the home to left front, but when you home the machine it goes to the right rear. When the laser is moved with the buttons it moves correctly. When I hit the limit switch it stopped but gave me an Alarm 8 code. What do I need to change so that I can home the machine?
In your move window at top (get position) what do your X,Y coordinates report when homed?
This might help.
Limit Switches - Diode Laser Wiki (diode-laser-wiki.com)
You need to change the $23 parameter. This is described in the article linked above.
If your machine is not a Pro Max, but is a new S30, these parameters should work for you.
$0=10
$1=25
$2=0
$3=4
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=7
$24=200.000
$25=3000.000
$26=250.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
