I am on it sir.
It did worked sir. it came back to home.
is anything i should try for any other issues like i can draw a square for 400 to 400 and hit frame if it goes for it. Before it did not so i had to make my camera setup with 300 to 300 mm
oh good news!
so now every time you ask it to home it goes left/front yes?
Yes sir. I tired to frame a 400 to 400 and it did and when i hit home it did went back to left front very well.
Great news!
now time to get some engravings on deck and see if all goes well
with latest firmware there is something else you might want to do
on LCD
Setup wifi, make sure it has access to internet
a) Contro â Pump > top right corner theres a little square with a globe, click it.
It will check the server for update, if there is one click UPDATE
b) control â laser â top right corner
Do the same
out of the discussion. I set my laser from the algo laser web support page and somehow i manage to use it with wifi connection without cable madness yet i attached a camera and i am again a slave of cables. It may sounds a silly idea but wouldnt be awesome if there will be a way to use the USB port on Algo Laser Delta to connect the camera wirelesslly ? I dont know anthing about how this theory can work but it will be a new era of diode lasers because it would be fun to watch the laser and control it while you are not breathing the smokes.
Maybe we could figure out a wireless WebCam! unsure if those would work with Lightburn! i do get you rpoint but passing through data via the WIFI connection of delta would be less than convenient as at the moment all that delta sends and recevives from lightburn is pure TCP telnet data
Webcam would really need more bandwith.
i will however check if there are any cameras out there with wifi and test!
well i am not a geek of course and the smartest person in room as well but what i did experienced in lightburn camera setup it just take a picture when we hit the update overlay. how all those working in the backround i dont know for me all of those are magic yet i had a makeblock laserbox pro 2 years back and it was a very pleasant feeling to see and control everything by your laptob and just wonder to ask you. Maybe it rings some bells and you guys come up a very new features)))
i tried to update the air pump and it found the update i hit the update and it failed tried again and it did and turned off the screen but i can see the laser head green lights all three of them on. Anything wrong or should i turn the laser on manually
I turned it on and tried to update but repeatedly failed. i will try to update laser
I turned off the machine and tried to update and i did the both of the update. now i will go for a test run. Thanks of tons for your leads sir. I am a very happy consumer because of your intense care.
Thanks for your efforts Gill - itâs always appreciated. Are you willing to host that video somewhere?
Iâd love to see whatâs happening.
We usually remove email addresses to keep people safe but youâve been around for a while. Iâd rather see answers out in the open for people to read and find.
Any time! Keep us posted if anything else happens
You have my email too if necessary
let me see if i can post here
But you will notice that the machine always pulls back from the place it is. is a over sensitive setting on older firmware
Basicly the friction of the frame alone is triggering the amp sensors of the TMC2009
There is a setting where we can lower the sensitivity of it, and i think on newer firmwares we did just that to accomodate to a bit stiffer frames
VIDEO: see if it works
so far i made test over and over again and it is coming back to home every single time. I will push the limits and try to find some issues for you to find out sir. It is a stressful but with your lead a joyfully journey in the same time.
Not sure if you have a host that could upload these videos in a better way (outside youtube?) that you could recommend?
