Appreciate prompt response. Rank amateur I am afraid, didn’t back up and did I think, amend vendor settings,long story. Cannot access controller directly using RD 8888 does not work, but via RDWorks I can get access via RD8888.
Its actually Ryxon controller I am informed but apart from different buttons similar to the Ruida.
Asking manufacturer for password and if RD8888 then clearly controller problem.
Regardless as I say appreciate you replying.
A bit of a cheek but if you get a minute do you think you could screenshot the vendor settings of your machine? I could attempt via Lightburn ideally or RDWorks to set the machine up similar to your own while attempting to gain access directly to the controller.
Given settings amended anyway nothing ventured nothing gained.
Yep as a newbie, didnt back up may have amended the vendor settings.
Tried 1 to 6 on controller and many others. Actually via RDWorks RD8888 gets me in which says possibly controller problem?
Was not aware there was a free Ryxon manual but have now found and downloaded, however if I have amended Vendor settings then will require to somehow get factory shipping settings or as I have asked from Jack that someone screenshot their settings and I will copy to controller via Lightburn.
Ok you hosed the configuration. You need to find someone with a ‘like’ manufacturer. Have you attempted to contact the seller and see if they can help you?
The problem is that these machines a built based on a Chinese Government approved ‘design’. Meaning any manufacturer can pick and choose what they put into the machine. A friend that has messed with these for almost a decade advised that two identical looking machines may have up to 10mm difference in part placement and/or mounting holes, alignment or anywhere else.
The point here is that you need the original configuration, such as steps/mm etc. If you cannot find that you will have to figure it out or…
Hopefully you can find someone here that can get you a copy of their .lbset (lightburns machine settings, when you save it) That will hopefully get you up if not perfect.
Here’s mine for what it’s worth. It’s from my ‘China Blue’ 50 watt, 5030, which is different, but it’s a start. Have no clue as to the compatability.
I still wonder why it didn’t work in the first place?
Good luck, hang in there…
Always use the most powerful tool on the planet before you fiddle with something…the Internet. Time spent there will save you many hours if not days or weeks.
I sense of humor certainly something you need when lasering.
I have contacted manufacturer and they asked, which password I required, explained the no access directly but also pointed out that even if gained direct access I would likely still need vendor shipped settings.
You never know they might just actually supply them (holds breath).
Again obliged for your settings which is as you say a start, will convert file and hopefully will read out alright to enter info.
Failing that did think about putting up another post asking for anyone with similar laser etc if the could post me or screenshot their vendor settings as you suggested.
Once again I thank you for your advice and information.
Despite initial set back looking forward to doing just that, moving forward.
Unless you and @jkwilborn have identical machines, his specific settings will only be enough to get you started at understanding the parameters and their effects. Perhaps this link in this post is as useful:
Your machine has specific stepper drivers, gear ratios, physical dimensions, triggers, etc that must be taken into consideration in various settings.
If it helps, here is how I have my Ruida 6445 currently configured (for the most part):
You will be up, I have no doubt
You need to loose that doubt
Tell me if I’m wrong, but I dropped the file there so you could read it via Lightburn and write it to your controller… Getting rid of the middle man (you.)
Hi, i have the same machine i believe, blue/grey Omtech 80 watt same controller.
I can upload a screenshot of the settings of mine in the morning, mine’s in the garage but no lighting (stops me being on it all night).
Chris, you should be able to ‘Edit → Machine Settings → Read’ it from your controller and ‘Save’ it to a file in the Machine Settings window. Just drop it to post it. Produces a .lbset file.
Roy should be able to ‘Load’ the file in lightburns Machine Settings and ‘Write’ it back to the controller. Keeps him from fat fingering things.
Thank you Chris,Jack giving me credit for knowing how to open an lbset file in Lightburn.
In no rush and would if not to much trouble screenshots preferred. Technologies all well and good but nothing beats info in a hard copy.
Belts and braces.
Besides will be interesting to see the differences in the various set ups are compared to Jacks and Jeff’s.
Sympathise with the dark garage, know the feeling well., add cold and you have mine.
Not a problem.
I knew nothing about these things until a few months back, groundworks most of my life so hadn’t a clue and compared to most on here, still don’t
Soon be joining you i.e the cold weather, east anglia here.
I picked it up from Russ. Without his help, I’d probably be lost. I also have my tube, mirror 1 replaced with his 1 piece model.
I bought this to learn on, it sure did that…
It also has taught me a lot about fundamental operation at the lowest level, with an engineer explaining the math along with it… I can consistently produce a 0.1mm dot at 1650mm/s. But there’s really no advantage of running at those speeds, except for the ‘thrill’ of it. Most of the best engraving appears to occur at slower speeds, usually below 300mm/s, in my opinion.
It does pay off in how big an image you can engrave, because what really matter is head mass. I can engrave at a reasonable speed and with the high acceleration ability it can slow down, turn around and go the other way in less distance than with all the weight it had originally.
It also increased the bed to 511mm x 340mm, and extra 440 sq/mm. I have engraved 12"x12" mirrors with the extra space.
I think the biggest epiphany of them all was the realization you have no control over power, just feed rate.
