It’s not easy to take a working machine and start hacking on it, especially with the initial cost involved. It doesn’t help that the ‘fear’ of this stuff drives most decision.
First time I took the head assembly apart I was uncomfortable, by the 10th time, didn’t think much about it and it went quickly. Now I take it apart at the least whim and don’t worry about it.
There are a lot of things to take into consideration if you wish to do an upgrade. I’m not completely done with mine operating at the level I want. However it is operational and hauls butt (censored the original word
) if I want it to.
The dpi game is another thing I question. Last years in high school we were allowed to take classes at the local college. I took one in lithography and really enjoyed it, ended up taking a bunch of them. Both those offset printers and our lasers have a common thread, in that it prints dots or ink/no-ink. Probably the best illusion for photographs to be printed in b&w as the press found.
Of course it depends on what you are doing, but I don’t know if I can get a dot smaller than 0.1mm at this point. I’m using a compound lens, properly focused (I hope…) but smaller dots elude me. This means that if I don’t want to ‘cover’ a previous ‘dot’ I must be at least that far away. Meaning that the best I can do with ‘dots’ is (25.4 mm/inch) / (0.1 mm dot) = 254 dpi. At best I can only get 254 dots in an inch. If I try to get a higher dpi, then I must be writing over my previous dots to some extent. That can’t be good.
Add to that some of these places advertise 1000 dpi for their lasers… dot size of 0.0254?
Moving by the end of month, so I’ll have access to my microscope then and I’ll have a better shot at seeing what I’m doing
I’ve used some of the other ‘dither’ type options, but don’t think I’ll be happy until I can make a good newsprint type image. Years of photography kind of spoiled me… I’ve gotten some pretty good images with some of the other options, but this is an area of expertise that’s on it’s own path I’d like to follow…
I think the slower I engrave the better the results, meaning the need for low power. I used to want a more powerful machine, I use the minimum possible, anything above the ~9% where it will lase. On my machine, maybe 5 watts, it would be double that on a 100 watt machine and make some of my images what I call ‘blown out.’ So I’ll probably stay in the zone I’m in as far as power. Speed wise seems to be around 150mm/s for most of my ‘engraving’ library.
Of course I could have another epiphany and change my mind
Take care, keep us updated.
