Rank beginner here, I’m sure my issue is not new, but my searching hasn’t found the answer.
I have a Comgrow Z1 grbl machine.
Every time I try to send a job to the laser, the machine moves to the home position at the upper right, trips a limit switch, and stops.
This machine is also a router. I had the same issue when using the router head, and stopped that by removing the autohome (G28) command from the gcode file.
I can’t figure out where I would do the same in LaserGRBL or Lightburn.
Just out of curiosity, what is your $27 set to? Often it is set to something like this “$27=1.000 ; homing pull-off, mm” which on my machine (a 3018 Pro) was not enough, and I had to change it to 3 ($27=3.000) to get it far enough away from the limit switch. Perhaps you could post your grbl settings (type $$ in the command line and hit enter) and then folks can chime in.
I’ve got it working, there was a setting missing in the manual from the manufacturer, the “Start From” setting. Once I got that correct it started working.
That said, the pull off settings is too close, so I will be experimenting with that.
