Homing opposite side of laser
I am having issues with my homing being the opposite of what it should be. I would appreciate any help that I can get. I have a Sculpfun S30 Ultra W22. It was working perfectly fine before I attached the Sculpfun Rotary Max Pro. At that time, it started rehoming to the opposite side of my laser. Once I detached the rotary, it is still doing it. Instead of going to the left front, it is going to the right front and hits the rail and shudders for a little bit. I have tried so many different things to fix it I am worry I will never get it fixed.
You can swap the x-axis direction in machine settings, open output settings and change the x-axis direction pin option.
But this sounds a little bit weird since you wouldn’t change this axis during rotary usage.
Thank you I will try this when I get home this evening. I have not done this before is there anything certain that I do?
