Homing Problem with consul stating Stream completed in 0:00 [MSG:Using cpu_map...esp32-s3] Grbl 1.1f ['$' for help]
After homing, and sending the job to start or frame, the laser hits its end stop and beeps. Consol states as follows: Stream completed in 0:00
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
Any ideas ?
Thank you
This doesn’t show any error. But I suspect that in the moment the laser should be turned on, the power supply voltage breaks down and the laser reboots. That’s a sign of a faulty power supply.
You need to show the entire Console window text, from machine startup tp the beep.
All the consol data is as follows
Waiting for connection…
usb connect succeed
usb connect succeed
ok
[VER:1.1f.20220810:]
[OPT:VHL,127,65536]
Target buffer size found
[software versions: CV50-Pro-MASTER-Release V1.0.0 20231129-1024]
ok
[G54:-nan,1.619,0.000]
G54 Offset values not 0
[G55:-nan,1.619,0.000]
[G56:-nan,1.619,0.000]
[G57:-nan,1.619,0.000]
[G58:-nan,1.619,0.000]
[G59:-nan,1.619,0.000]
[G28:-nan,1.619,0.000]
[G30:-nan,1.619,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Homing
ok
?<Idle|MPos:0.025,0.025,0.000|Bf:127,65535|FS:0,0>
Project loaded in 70 milliseconds
Starting stream
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
On or near line 5:
Starting stream
[MSG:Pgm End]
Copied from PM.
Alarm 3
Are you using Absolute Coords? What your information indicates is that you have an over-travel situation for some reason. Could be positioning, or could be the Overscan is too high if a FILL or Image is being processed.
