I have an Ortur M3, YRR rotary
This is the message I get when Trying to frame
These are the codes Im getting when trying to frame. Can anyone please help me with this or steer me in some direction tell me how to enable the homing in my GRBL settings.
Thanks
Thanks
Waiting for connection…
Port failed to open - already in use?
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:210]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230223]
[SN:2B7F7E2CEEA0CCA818F6FF7667249A85]
[VER:1.1f.20220325:]
[OPT:VNTSL+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:84:F7:03:E6:88:76]
[IP:10.0.0.26]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
Homing
error:5
Homing cycle is not enabled in your Grbl settings.
[MSG:25:Info: USB SERIAL STREAM CONNECTED]
Ortur Laser Master 3 Ready!
OLF:210.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
error:5
OLF:210.
OLM:GENERAL.
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:210]
[OLM:GENERAL]
[DATE:20230223]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:10.0.0.26]
[PLUGIN:YRR v1.00]
ok
Homing
error:5
<Idle|MPos:7.7953,7.8315,0.0000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|WCO:0.0000,0.0000,0.0000|VA:24581,63>
ok
Starting stream
Stream completed in 0:00
<Idle|MPos:6.2331,5.0469,0.0000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:24578,60|Ov:100,100,100|A:SFM>
ok
[GC:G1 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F236 S0.]
Starting stream
<Idle|MPos:6.2331,5.0469,0.0000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0>
ok
Starting stream
error:5
error:5
OLF:210.
OLM:GENERAL.
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:210]
[OLM:GENERAL]
[DATE:20230223]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:10.0.0.26]
[PLUGIN:YRR v1.00]
ok
Homing
error:5
error:5
OLF:210.
OLM:GENERAL.
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:210]
[OLM:GENERAL]
[DATE:20230223]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:10.0.0.26]
[PLUGIN:YRR v1.00]
ok
Homing
error:5
error:5
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:210]
[OLM:GENERAL]
[DATE:20230223]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:10.0.0.26]
[PLUGIN:YRR v1.00]
ok
Homing
error:5
Starting stream
error:5
On or near line 0:
error:5
On or near line 0:
error:5
error:5
error:5
error:5
error:5
error:5
OLF:210.
OLM:GENERAL.
<Idle|MPos:6.2331,5.0469,0.0000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:24578,66|Ov:100,100,100|A:SFM>
ok
Starting stream
ok
Starting stream
ok
Starting stream
Starting stream
Layer C00
Stream completed in 0:13
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
OLF:210.
OLM:GENERAL.
[MSG:‘$H’|‘$X’ to unlock]
error:9
G-code locked out during alarm or jog state.
[MSG:3:Warning: Caution: Unlocked]
ok
