Homing with rotary
How come my laser head will not home in rotary mode and will only engrave where i physically put it
There’s no limit to how far you can travel around a cylinder and
the limit switches on the gantry can’t tell the rotary that it has arrived at the home position. The engraver may be told to home. If it tries, it will over-travel and generate an error message.
It’s highly recommended to disable the Auto-homing feature when using the rotary.
Which Ortur Laser engraver are you running?
Laser master 2 pro S2 LU2-10A
Also my images engrave way larger than the template shows and images engrave with lines in it bad. Looking grainy.
If you’re interested in sharing what you’re seeing you can drag and drop pics of the engraving into the reply window here.
