Hello. Tell me if your program has the ability to turn on the laser at minimum power in order to use it as a “sight”. If yes, how to do it? Thanks in advance.
- Go to Edit->Device Settings
- Enable “Enable laser fire button”
- Enable “Laser on when framing”
- Go to Move window
- Set power to an appropriate low level and press Fire button to test intensity. Adjust until appropriate for your situation.
Laser should now fire when framing a job.
Thank you so much!
