I installed Lightburn on my new computer and did the lens calibration and camera alignment and now the image is upside down in Lightburn.
How do I flip that? It was fine before I calibrated and aligned,
Thanks
Ray Mc
LightBurn uses the Camera Alignment process to understand the orientation of the camera. When you went through that process did you select the target markers in the numbered order? If not, your orientation will be incorrect.
If not, go through the process again and select the targets is numbered order. Note that you will need to reburn the targets unless you have a way of perfectly relocating the targets used during the previous alignment.
