How can I set to have something like a laser mark? So I can know area that will be engraved.
I have Sculpfun S30 Pro. I have a problem as I where is the start point.
Thanks a lot for your help.
This may be of interest:
Are you asking how to see where the laser is for framing purposes? If so, there are checkboxes in device settings, enable laser fire button and laser on when framing. This will allow the laser to fire at low power while running the frame command so you can see where it falls on your workpiece. You may need to adjust the power % to get acceptable results, just keep it as low as possible so you don’t inadvertantly lase something.
Another starting guide for your laser. This includes setup and most common options to use:
Under the MOVE tab on the right side of the workspace, there is a FIRE button that you can set the laser to a low power ON to indicate current position.
I use the FRAME command for every cut I make. SHIFT+Frame will frame with a low power laser light to show the the max area for the cut areas.
The Rubber Band FRAME will show a rough outline of the cut
Thank you so much.
Your explanation is very clear and detailed.
I do appreciated your help.
Thank you.
Thank you so much.
Thank you very much.
Thank you so much for explanation.
I can work on it.
