Please help ,How do i adjust speed or power on my machine during burning
when using smoothieware.i know its possible using GRBL firmware .
I’m not certain what you’re asking.
You should consider running the material test and coming up with settings that work for what you are attempting and generate your settings accordingly.
Adjusting speed and power while working isn’t a conventional workflow.
Hi thank you for your response what I mean is that
say my initial settings are mode =line and spd/pwr =4.0/30 then I start cutting then I will realize that I can actually cut faster now I can’t adjust on the fly (using the move button ) since lightburn doesn’t give that option for smoothieware.
