New user here and I’m wondering if there’s a way to make an equilateral hexagon without having to calculate and set the width and height. Also once I draw a hexagon, is there a way to rotate it without the shape getting distorted?
Holding Shift while dragging will lock the width and height, producing an equilateral shape when using the drawing tools. Set number of sides of the desired polygon.
The polygon tool is used to draw regular polygons, like hexagons. Holding Shift while dragging will lock the width and height. Holding Ctrl will drag the polygon from the center, instead of the corner. Creation Tools - LightBurn Software Documentation
Rotate is discussed here: Creation Tools - LightBurn Software Documentation
And here: Numeric Edits - size, position, orientation - LightBurn Software Documentation
