Hi!
I have a shape (a triangle, an irregular one…) and I want to fill it with vertical lines.
Is there an “easy” way?
(like the mask thing on images).
Any help wellcomed.
Hi!
Any help wellcomed.
You could try using the settings to rotate the fill direction (scan angle ) and the line spacing…above this setting…
Here in the image angle is now 90 degrees so vertical and spacing 1.21mm or 20.99 lines per inch.
Adjust to your likings
Hope it works for you
Not a bad idea, will check
Let me know please ,
It did the work! Easily and fast! Thx dude!
My Pleasure thanks for solving it, in the choices
