Hello:
I saw a video showing how to choose which laser to use with an XTool F1, but I can´t find the buttons , Please help
For the F1 Ultra it is different. You need to manually add a different line in the gcode.
I saw a video on Facebook of someone that made two different profiles in Lightburn to easily switch between the two lasers.
Solution is very easy.
Duplicate der F1 ultra profile than go to device settings G-Code and just insert the two lines for the IR activation under the start Code parameters in one of the Profiles
Then you can switch between the two F1ULTRA profiles the one makes the blue the other the red Laser.
Thank you so much, This was really helpfull
