How do I import pdf (PCB) properly in lightburn?
My pdf file exported from eagle looks like this:
But when I import that file in lightburn. It looks likes this.
2
Also, when zoomed in I see these lines, which I don’t want. I want it to be completely solid.
3
I have marked the problematic areas. How can I resolve these issues and also since I’m engraving it with laser, How can I invert the pdf ?
I found some resources in this forum recommending to use outline to invert the pdf but I can’t figure out how to do it.
LightBurn does not handle stroke width, and it doesn’t use “paint”, so anything that “paints over” a black shape with white won’t have the desired effect. If Eagle can export as a high resolution image, I’d suggest going that route instead - LightBurn will engrave from a black & white image just as easily as from a PDF.
I found the really easy and fastest way to this. For anybody who comes looking. I’m listing all the proper steps here:
  1. In Eagle, Click “Options > Set > Misc” and change uncheck these options listed below.
    1
  2. In Layer Settings, select the following layers (For Bottom copper select Bottom layer instead of Top).
    2
  3. Click “File > Export > Image”. Select the highest possible resolution (2400 dpi) and click “OK”
    4
  4. Now the generated image is already inverted. No further modifcations are needed. Just import it directly in LightBurn.
