How do I invert corners on a rectangle
If you are after rounding all corners, look to the ‘Shape Properties’ window, and adjust the ‘Corner Radius’ and enter a negative number.
You can also use the ‘Node Edit’ tool to produce rounding to the inside for individual corners. :slight_smile:
