Hi All.
Is it possible in Lightburn to make notes for the individual elements.
Notes on what the element is, what material is to be used and where it belongs in the project.
With your project open select âshow notesâ from the File dropdown menu, the following pop up will appear.
Input your notes, the note will be saved with the project
I hope this is what you were after
Not quite. For a project I draw many elements and I would like to be able to add a note to each element, in order to remember what this specific element is and where it belongs in the whole project.
How do I use âShow Notesâ for that?
I have Cypcut for the metal laser. This has a list of the parts. The file name remains there. The list is used for nesting.
Unfortunately, Lightburn doesnât have that.
I use layers T1 and T2 for this purpose (also).
I draw a frame and write the information I want in there. You can also use another ânormalâ layer that you donât use on a daily basis and make this layer permanent/exclusive to you note layer.
I use T2 for drawing notes that are specific to the part.
CTRL+ALT+N is the keyboard shortcut for notes.
Letâs say a project consists of 20 different parts.
I would like to be able to make a note on each and every one of all 20 parts.
What part it is and where it belongs in the project.
âShow Notesâ can only show notes you write about Lightburn itself and what else you have to remember.
It cannot be used for what I want.
Peter, you may need to change your post heading so that you donât get a response for âadding standard notesâ in LB.
Apart from that, I donât think there are any other solutions than those already named.
