I designed a file in lightburn, sent it to the machine, but never saved the file… is there a way to pull it back and onto lighburn?
File list window then refresh
Yup, no problem… now how do I open that file to open it… that is where I got stuck in the first place
https:// Documentation/Toolbars.md at master · LightBurnSoftware/Documentation · GitHub
" Hit the Refresh button to query your controller for the list of hosted files. You can select a file and press Start to cut it, Delete to remove it from the controller, or Download to save it locally. "
Oh! That helps!
Thank you!
I’m not 100% sure that was ever implemented. The file would not be easily edited, in any case, as the data sent to the laser is the final baked version, and unless you just want to re-send it, all you’ll get back are cut lines. You don’t get the outlines of filled shapes, bitmaps, or cut layer settings.
