Hi! I’ve got a couple of settings files for my laser: laser.RDVSet and user.RDVSet. How do I send this to my laser? LightBurn doesn’t recognize the files when I tried to read them from Machine Settings.
I’ve got a Ruida 644XG with a USB port. Can I use a thumb drive?
Thank you!
EDIT: Solved! I changed the name of “Laser.RDVSet” to “Laser.lbset” and now LightBurn can read the file. All good.
This is most likely a coincidence of behaviors, as it might attempt to parse the file, but we can say with near certainty that the internal format will not be the same, and it probably didn’t load these settings, unless you obtained an LightBurn file that someone renamed the extension and you have named it back to its original format.
Where did this “Laser.RDVSet” file originate, or where did you get it?
