I designed a file in LB and want to open it in Inkscape, so I can print it in color. I made a file, but after I save it, I can’t find it when I try and open the file in Inkscape What is the correct way to do this? Thanks.
Use File->Export to save the file as .SVG. However, certain elements won’t necessarily carry over. For example, text will not export as text but will be converted to path. Looks like images are supported which was a surprise to me.
Thank you!
