Whenever I home my machine, it hits the position pretty hard. It could be more accurate if I could slow it down but I don’t know where to do that. I’ve tried lowering the speed on the ‘Move’ tab, but that doesn’t seem to work and I can’t find it in settings or setup any where. Help!
As far as I know you have no ability to change any such configuration on xTool machines. xTool have disabled the ability to enact or save changes on their firmware.
If you’re able to do it at all it would be something available in XCS.
Thank you.
I’m curious. If you can set the speed of the move buttons, why would setting homing speed be a firmware issue with the xTool machine.
Homing is managed exclusively by the controller. Jogging controls are managed by discrete move requests with accompanied speed settings from LightBurn to the controller.
Ok. Thanks. I understand now. Your expertise is appreciated.
