How do I stop the path burns?
Read here for the most common GRBL settings issues: https://github.com/LightBurnSoftware/Documentation/blob/master/CommonGrblSetups.md#short-version
I did all that when I first set it up…never had an issue until tonight… Does it drop off sometimes?
“Does it drop off”? I’m not sure what you mean by this. If you have LightBurn on a CNC machine, the $32 setting will likely be disabled by CNC software when you use it, if that’s what you’re asking.
Ok thank you…will try that today…
