When I select line +fill how can I use different power and speed settings for each function? I’d like to perform the fill first at 150mm/sec and 15% power. Then have the same item outlined at 40mm/Sec and 12% power. I assume this can be done but dont see the settings anywhere.
If you double click the layer coloured square in the cut planner, it will open a new dialog where you can set the two options. At the top are the normal scan (fill) settings and at the bottom are the cut (line) settings.
Hope that helps
David
Perfect. Thanks!
