Every time I pick up a new sheet of plywood or acrylic, I lose material guessing at settings. I want to make a proper test grid my standard first step and would like to hear how others set theirs up. This is my current plan:
One grid per material and thickness. Even the same species of wood can behave differently from batch to batch.
Speed on one axis, power on the other. A simple grid makes the sweet spot easy to see at a glance.
Separate engrave and cut tests. The settings that give a clean engrave rarely match a clean cut.
Keep focus and air assist constant. Changing several things at once makes the results hard to read.
Label every square. Small engraved numbers save a lot of confusion later.
Test multiple passes too. Two faster passes sometimes cut cleaner than one slow pass.
Save the results in a material library. Writing them down once means I never repeat the same test.
I am still unsure how big each square should be and how many steps of power and speed are worth testing. How do you lay out your test grids, and what do you record once the test is done?
Your list looks great and there is nothing missing.
Typically there are only a few tests in total that need to be carried out, I think I work with 4-5 different materials in 3-4 different thicknesses, plus the few rare exotic materials. So once you have done the “basic test” once, that is your starting point in the LB material library. I use the respective values and do a small safety/fine-tuning test of each new material delivery/order.
I also have all the tests, which can also be pictures or small collections for kerf tests, in a “collection” or hung on a nail list, all at close range and eye level.
As test patterns I mostly use 10x10mm, 6x6 rows.
You have a good point about documenting everything, otherwise the tests are worthless.
I’ve had a hard time figuring out how to pick the initial range for the test cut array, given my laser and the material of interest. A few times I’ve done this and everything got cut through, more frequently, though, everything was just engraved. Related to that, figuring out what a good value would be for the step variation (speed, power) has also been just a matter of wild-assed-guessing.
It would be good to engrave the parameters onto each block, as well as in the legend for the array. That’s particularly true for cutting, so you can inspect the resulting cut-out box cut sides to see how dark the burn marks are, etc.
Also, some guides here from experts like Bernd.DK on his test cuts, showing what he’s looking for in terms of ‘best results’ would be good advice to the beginner. I’ve built a lot of laser-cut kits, so I kinda know what ‘good’ should look like.
It is, like many other things in life, very individual
I consider “good” in connection with laser parameters, fast and as little as necessary power, but not the fastest and least power.
It turns out (for me) a small margin of 10-15% on the safe side means that I don’t have to cut the same place twice, just because the material changes in the plate a little.
Starting values are very machine-dependent and very rarely copyable.
But typical procedure here with me, with an “unknown” or new batch of material, would be:
Let’s say it’s 3mm MDF from a different supplier than the one I normally buy from. I find my old test and or retrieve the values from my LB material library. Here I can see that my max speed was 38mm/s at 55% power, but it also says that I thought this time that 25mm/s at 40% power was optimal…
So I will start a quick test with 25 to 50% power and 15 to 35mm/s in speed. This gives a test pattern of 5x5 fields.
By the way, I usually run round circles instead of squares.
From the small test I choose the one that is in the upper third of the test and that looks safest to produce.
These are all laser cutting tests, engraving is a completely different chapter and there are many more parameters involved. But a reasonable starting point and so fine-tuned there, it is almost the same procedure, just a few buttons to screw with.
PS thanks for the compliment, but I certainly do not consider myself an expert but more like a gradually practiced craftsman.
If your designs are mostly short moves, use 5mm-10mm squares in the Material Test.
If your designs have a lot of long sweeping or straight moves, use 25mm-30mm squares.
Short moves do not let the laser to get up to programmed speeds. If using variable power, that also means you will not get up to full power. So those small squares will not translate to actual results if doing a larger project.
Your plan already covers the important parts. A couple of things that help us: LightBurn’s built-in Material Test tool (Laser Tools > Material Test) builds the speed/power grid and labels it for you, so you don’t have to draw it by hand. Around 10 mm squares with 5 to 7 steps on each axis is usually enough to spot the range, then run a second, finer grid around the best square. For cut tests, also note the kerf you measure on the result; it matters a lot when parts have to slot together, like tabs and slots in 3 mm plywood.
I’d keep it on, as long as you run your real jobs with it on too. The point of the grid is to predict what your actual project will do, so the test should use the same mode, acceleration and line lengths as the job. If you switch variable power off just for the test, the squares will look stronger than your real cuts. What MikeyH described is mostly a square-size problem: if your projects have long straight cuts, use bigger squares so the head actually reaches the programmed speed, and the result will match much better.
If we’re talking about the same thing, variable power is a super nice way to create test rows.
But when you’re at a stage where there are only 4-6 rows and lines, it’s almost faster (for me) to knit it together without this nice function.
The answer comes from understanding why variable power exists…
Constant Power: When the laser slows down to stop for a direction change or reversal. the full power remains on. That can cause excessive burning in corners and at the end of lines.
Variable Power: As the beam approaches a stall point, the corner or end of a line, the output power is reduced as it approaches that point. This is entirely done in the laser controller. The net result is to obtain basically even burn results at any speed, within limits of course.
