How long should I run the fan after laser was in use, before I switch off fan
How long should I run the fan after laser was in use, before I switch off fan.
Laser is Sculpfun S30 Pro Max
Which fan? The laser cooling fan? Since it cools down fast, you can turn that off nearly immediately. Maybe 30 seconds. The fume extraction fan should run a little more to make sure all fumes are removed. This depends on the power of the fan.
