How to activate or solve the GPIO problem - CREALITY FALCON
Ожидание соединения…
e[0;32mI (1402) serial: Line state changed! dtr:0, rst:0e[0m
ue:0.000000 spindle_pwm_max_value:1023.000000
Grbl 1.3a [‘$’ for help]
e[0;32mI (205379) serial: Line state changed! dtr:0, rst:0e[0m
ok
ok
Наведение
e[0;31mE (207090) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (207092) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (211272) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (211274) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (211275) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (211277) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:03
Starting stream
[MSG:Pgm End]
Stream completed in 0:01
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Stream completed in 0:02
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Project loaded in 0 milliseconds
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
<Idle|MPos:1.000,274.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
e[0;31mE (985104) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (985106) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (985108) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (985109) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
e[0;31mE (1005366) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1005368) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1005370) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1005372) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (1005376) ledc: ledc_set_duty_with_hpoint(698): hpoint argument is invalide[0m
I believe this error messages are not necessarily a problem.
Does your Creality home correctly? At what point on the engraving process does this error appear in the console window?
@Creality_Rachel
when scanning the engraving space
Did you create the device manually or auto?
Make sure you selected GRBL device from the list
Also in the console window, could you copy/paste the whole output here
Also a full screenshot image of
  • your Lightburn window with the project open
  • Edit → Device settings page
so it’s not an installation problem, it’s just a momentary error, due to an incorrect use of the program?
Uncertain until we know more :slight_smile:
Впишите сюда текст цитат
this usually happens when I click Frame
ok
ok
Наведение
ok
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
Starting stream
[MSG:Pgm End]
ok
Starting stream
Seems to be just the debugging, that’s still enabled as output
Does the machine engrave correctly?
Try running this file if you can in absolute coordinates mode
Dot Test with Angle.lbrn (46.3 KB)
Yes, it engraves everything correctly, but when scanning the workspace, these errors sometimes appear.
I tagged Rachel from Creality that might clarify, but I think is just some debugging data from firmware that wasn’t disabled. I think you can disregard those errors if the engraving it is working.
Probably someone with a Creality might confirm this too. Lets see what others say
e[0;31mE (5885968) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5885970) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5885972) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5885974) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
<Idle|MPos:-32.975,-57.550,0.000|FS:0,0|Pn:Y|WCO:0.000,0.000,0.000>
ok
Starting stream
e[0;31mE (5990847) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5990848) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5990849) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5990851) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
<Idle|MPos:-66.037,-95.550,0.000|FS:0,0|Pn:Y|WCO:0.000,0.000,0.000>
ok
these errors happened when I click frame.
besides this, the laser engines make a sharp sound when they reach the end and it’s as if the brake sensors don’t work.
Does the machine home correctly when you power it on?
Also, you are in negative coordinates, are you in absolute coordinates mode?
These are after I tried to scan the model you sent me.
what can all this be?
I now tried again to perform this project only as from the middle of the area and it did it perfectly
but if I start it at the extreme edges or at the corners, the error appears that the GPIO is not installed.
is it possible you are ussing current position or user devfined instead of Absolute coordenates?
[quote=“gilaraujo, post:16, topic:132864”]
[/quote]yes, this is probably the problem
thank you very much
I hope it’s not another problem
Got news from creality Rachel
Your firmware is old needs to be updated
Please refer to manufacturer documentation for “how To’s”
To add on, it only works with the Falcon2 series (12w/22w/40w lasers). If you’re using a CR Falcon, the firmware has not been upgraded to hide these codes yet. Yet you can ignore them, as long as the laser is functioning properly.
thank you very much for your help, it’s resolved
