I’m just staring with LightBurn and laser cutting/engraving. When I try to cut a circle with a few shapes inside, the laser also cut between the shapes. I searched where to set the min power option but couldn’t find it, apparently that option is not available on LightBurn 1.2.04, so I don’t know hot to solve the problem.
The image bellow shows in green the two lines that are supposed to be skipped, but they are also cut.
Hey @Mooseuk, do you know why the power in Laser mode might be much lower. After I run $32=0 on the console the laser power can be adjusted in the Max Power option of the layer, but it burns between shapes. After I run $32=1 to enable laser mode, the power is too low, and it seems as if the values in the option Max Power are ignored.
