How to burn a framing outline to align my material
how do I burn a framing outline to align my material
Not sure just what your asking.
Just like any project, draw your outline and set your speed/power on line mode.
Sounds like you’re asking for a jig. I take a piece of cardboard and lay it on the cutting surface, and then cut out an outline half a millimeter larger in width and height than the project. I make sure the cardboard doesn’t move, and I put the tile or coaster or wood into the jig, and hit start. The key to the system, is making sure the cardboard jig does not move when you take out the piece.
As @JimNM stated, if you introduce a few side holes to you can put fingers to grab the piece easily you will reduce the chance of moving the jig.
