How to change dimension for whole plan
Hi, I make a wooden wine holder and I need to change the dimensions for the whole plan of the holder. Well, I need to reduce it by about 20 percent. Does anyone have any best practices on how to do this in LightBurn to make it accurate?
You set LightBurn to 80 % and get a 20% smaller object (everything must be selected)
If these are a ‘finger’ type or have specific size notches or holes to put parts together it could be a problem.
This was worded so badly, I’ll try and illustrate…
I built a stereo cover that was generated by box.py site. It’s figers are based on the thickness of the material.
It’s larger than my machine, designed symmetrically so I can cut each corner separately.
I cannot just make it 20% smaller, the ‘notches’ won’t fit anymore…
stereo-corner
Make sense?
Good luck
I sometimes scale 4mm boxes with finger joints down to 3mm, with the even numbers it goes very well, 75% and you are down to just 3mm :wink:
(4 mm and 3 mm material thickness)
I could see that. What I was referring is to the same size material used to make a smaller box…
Different paths… :crazy_face:
