How to change line mode to fill mode? in cuts/layers
How to activate engraving mode in Light burn? Normally changing from line to fill mode but in my case the fill mode doesn’t work
What do you want to achieve? Line mode is also an engraving mode. Engraving and cutting is a matter of power per time, not which mode you use.
Simplest explanation is your shape isn’t closed.
Are you talking about when you send to the laser it won’t fill or what you see on screen in the design area? If you’re talking about what you see in the design area, you probably have filled rendering turned off. Go to the Window menu and check one of the filled options.
