Hello
How can I change the default settings for the “MOVE SETTINGS”?
The speed per default is 45. I dont remember what I changed, but before it was 6000.
Where can I change this?
Heres a pic.
Hello
Heres a pic.
Not sure exactly what you mean. You click in the box and input setting or use up/down arrows.
Take a look at the Units and Grids tab in Edit → Settings, because you may be running in inches rather than millimeters.
I mean to change it by default. Whenever i reset LB, it goes to 45 again
I don’t think you can change those default settings. But LB stores this value. It should stay after restarts / reboots etc. If you reset it, it gets to the default value, of course. But why would you do constant resets?
