How to change my green home location
I just installed light burn my laser is a ortur 2 just got it …in the setup it i had 4 choices for the home location bottom left right top or top left…i picked bottom left having a hard time moving the home position in the middle of my grid …can anyone help me
Home is where it goes to find the limit switches if installed. It establishes the Origin position.
Origin is where you do not Home and tell it where the 0,0 point is located. If Home in the controller is not enabled (need switches), Origin is where it is sitting when you power it up, but you can change it if you want.
Some reading material:
The machines origin tells the controller which quadrant it’s operating within. All machines home in the center of this graphic, then the origin tells it which quadrant.
If it homes at the bottom/left it’s operating in quadrant I.
quadrant-i
My co2 homes to the back/left, so it operates in quadrant IV
quadrant-iv
The green block tells you where the objects job origin is located.
Don’t confuse it with the machines origin you set in the device settings.
thank you for the help just about ready to send this thing back…going to give it another try thanks again
