Hello,
One time I see it before but now I don’t found that setting , to change speed from Seconds to minute , any speed now in seconds . how to change it please ?
Settings:
Thank you for reply, but in the Edit menu is no setting, it’s only Device setting or Machine setting, and I did not see that windows , now,
It’s under Edit → Settings
Click the “yellow” icon.
Thank you so much
done.
Ah, you are on a Mac. Just for completeness: Then it’s probably under the Apple menu. The shortcut for application settings is usually AppleKey + comma (I don’t use international keyboard layout, so it might be different), that should work as well, I guess.
