Hello, I have a problem with an open form. I would like to engrave it, so I’m going to fill it. However, I get an error message saying that a shape is not closed and that two elements (presumably the two circles) are affected.
What do I have to do to close the two ends of the circle? I have already drawn a small line from the upper to the lower circle on both sides. The line was exactly at the ends of the circle but I still got the error message.
Grab node on bottom and drag it up and connect to upper line node on both sides.
If you leave fill on in cuts/layers you will know when shape is closed.
