How to combine 2 cuts?
hi
i often make boxes (MakerCase - Easy Laser Cut Case Design )
i see that some sides can be put together (shape is the same)
i tried to simulate this with 2 rectangles. but no luck line in the middle is lasered 2x
is there a trick to combine these 2 lines ?
i justr try to reduce burntime
thanks
test combine.lbrn2 (3,0 KB)
Have you checked remove overlapping lines?
hi bernd
thanks this is the solution
have a nice day
jean-marie
I am pleased that you succeeded.
But that solution mark should have stood on the post that solved the problem. (It just makes it easy to find for others, otherwise it’s not a broken leg :wink:
