Hi all! I can connect my P2 to windows via Wifi but can’t seem to control from Lightburn, I’ve been through most of the posts here on the topic and have tried manual IP but so far I have not been successful in getting Lightburn to control it. Any ideas? Thank you, grateful for any assistance.
Make sure that the IP address you’re using in Lightburn matches the one assigned to your ACMER P2. Also, check if the firewall on your Windows machine is blocking the connection. If you’re still having issues, try restarting both the machine and the P2.
I think I’m missing something with the IP, I did that but no luck. Will keep trying, thank you so much for the helpful reply.
