I need to engrave a pdf file to a lightburn file in order to engrave as a fill of offset fill - how would I do that ? As I open the file in lightburn the mode shows “image” - can I change that to fill ?
You might need to trace the image. Post your PDF so we can take a look.
I did a trace and it did the job for me. Now I can add some speed and power settings to the fill mode. works great
thank you
It is a key concept to understand the difference between an Image and an Object. You are headed to laser greatness!
