My laser bed is 20" x 12". I want to create a circle that is 18" in diameter. To do this, I need to split the circle in two pieces that will be 18" x 9", but one piece will have 3 male tabs and the other will have 3 female inserts for the male tabs, so that the 2 pieces can be connected together to form the 18" round. Can anyone tell me how to go about accomplishing this? Thanks!
Not sure how well I can explain this but here goes, Draw a line through the 18in circle, Draw 3 rectangles the double the thickness of your material x say 3in and place them centered on the center line where you want the Tabs/slots, then use node edit to get the semicircle shapes with tabs and slots. Actually easier to do than explain.
18in Circle.lbrn2 (15.4 KB)
Here is a way to do it with dovetails. Each layer gets an outward kerf offset.
Draw a 18" diameter and place the center of it at:
Xpos 9.25
Ypos 9.00
Select circle, right click, and convert to path
Draw a 18" line
Draw a polygon
Change shape properties as shown
Position the center of triangle at:
Xpos 9.25
Ypos 9.00
Select triangle, right click and convert to path
Duplicate the triangle and move the duplicate 6.25" to the right
Duplicate the center triangle and move the duplicate 6.25" to the left
Highlight the 3 triangles and the line, and go into edit nodes mode
Trim out the tops of the triangles so it looks like this
Select the dovetail, and Auto Join Selected Shapes
Put a 0.125" radius in the corners highlighted
Duplicate the dovetail shape and the 18" diameter circle
Move the duplicated shapes 20" to the right
Move the duplicated shapes to the black layer
Go into node edit mode, and delete the bottom of the red circle and the top of the black circle
Select all and Auto Join Selected Shapes
Move black shape 20" to the left
Set outward kerf value for each shape
Excellent description of how to do dovetails!!!
