I recently came across litmaps and inciteful. They are hugely helpful for exploring an area of research.
Hey Fins, Thank you so much for helping me out with the research !! Youâre a saint for real.
Can you please explain in a more simpler way tho how to generate the images?
Do i need to download python and try to run the Rougier method? cant this be done in lightburn itself?
I tried to do this by using photoshop first to edit as you said. but i cant figure out how to tweak the parameters in lightburn as you said. heck i cant even get it to make circle dots anywhere ![]()
Absolutely mindblowing artwork ![]()
Thatâs because you donât do anything in LB. LB is only the last step to laser the finished graphic. The processing is done before. As Fins described, you need to prepare your image and then let it be processed by one of the tools he found / created. This is manual work and requires manual tuning. Afterward, the finished image is transferred to LB.
You should be able to use Python and/or compile code. Otherwise you canât use the algorithms directly.
You can make the window bigger by changing the DPI.
Cool! I was afraid this was a Dead Thread!
Had not seen this thread beforeâŚGreat reading (and interesting threads with such regularity), thank you all.
Halftoner ![]()
First - Halftoner_V1.7, second - Reactor_V1.2.
Real old proggies.
Halftoner.exe.txt (61.5 KB)
Reactor.exe.txt (23 KB)
With Processing + SquiggleDrawâmaster.zip.txt (115.8 KB) + controlP5-2.2.5.zip.txt (1.2 MB)
I used to have Halftoner, but I canât find it on my backup, and it isnât on the internet anymore, but maybe I am not looking in the right place ![]()
