The way this is set up as one cut line the Laser will cut the outside line first which will allow the pattern to shift I would like it to cut in the folowing orde A, B, C and last D is there an easy way to do this
There’s an easy way to get B/C, then A, then D which I believe gets you the stated desired outcome if not the exact order as you’ve listed.
If that works then enable “Optimize Cut Paths” in Laser window. In Optimization Settings, make sure that “Cut inner shapes first” is enabled.
I learn something new everday, Thank you MR. B
