How to cut objects to fit Lightburn workspace
Hello. I would like to cut a object that is 10cm in length into 3 parts so as to fit in the Lightburn workspace. My workspace is 400mm by 415mm. Creality Falcon Pro 22W. Running latest version of Lightburn. I would like to cut the part with a “jigsaw” to allow a proper glue up when I join the parts later. Thanks, Tom
If you have space under the laser you can split the project in 3 laser jobs but move the piece for each job.
If you can´t then use the Cut Shapes tool.
Make 3 copies of your project and draw 3 squares that you can Dock to each other then apply the tool.
foex.lbrn2 (16.3 KB)
10cm = 100mm. You can get 4 of your items across your workspace. Ask your question again and include pictures so we can see what you’re working with.
