I am a first time user. I can’t figure out how to cut out an object. I figured out the engraving, but not the cutting
If you want to cut, in the layers menu select “Line”. “Line” can either be a line engraving or a cut. If you want an engraved line, test for a low power fast speed. If you want to cut, generally you will need higher power and slower speed. It depends on what you want to cut or engrave.
Lightburn has a channel on YouTube: https://www.youtube.com/channel/UC-TdV9ThMD6E4MZztA6eZsQ/videos
A caution, to keep you from being confused by terminology: the earlier versions of Lightburn you see in the beginner videos have different terms in the layer/cuts menu. Translate those terms from “Cut” now means “Line” and “Scan” now means “Fill.”
Have fun learning all this!
